Philips - V680
by Philips
Ventilator
The Philips Respironics V680 is a critical care ventilator that combined a single-limb NIV with a fully featured dual-limb system to deliver life support for critically ill patients in the ICU. The Respironics V680 can easily and quickly switch from invasive to noninvasive ventilation. This Philips ventilator provides continuous measurements of dynamic resistance, compliance, elastance, and plateau pressure in both single and dual-limb invasive and noninvasive modes.
Combines the proven performance of the Philips V60 noninvasive ventilator with an invasive ventilator for ICU patients.
Same look and feel as the Respironics V60 Ventilator.
Built-in apnea backup for both invasive and noninvasive spontaneous modes.
4 hour battery backup.
Uses Auto-Trak technology to automatically adapt to your patient’s breathing pattern.
Supports adult and pediatric patients.
Dimensions
  • Height: 13.5” (34.2 cm)
  • Width: 18” (45.7 cm)
  • Depth: 17.1” (43.4 cm)
  • Weight: 27 lbs (12.3 kg)
Patient Types
  • Adult: >20 kg
  • Pediatric: 5 to 20 kg
Pneumatics
  • High-pressure oxygen supply: 2.76 to 6.00 bar / 276 to 600 kPa / 40 to 87 psig
  • Flow: 175 SLPM
  • Air Supply: Integrated centrifugal-flow compressor
  • Exhalation cartridge (eSYS)
  • Flow sensor: Exhaled gas flow accuracy: +/- (0.1 SLPM + 5% of re ading)
  • Diaphragm/seat area: 6.6 cm2
  • Diaphragm/seat diameter: 29 mm
