Microplate
The SpectraMax® iD3 and iD5 Multi-Mode Microplate Readers measure absorbance, fluorescence, and luminescence. In addition, the iD5 reader measures TRF and FP and can be expanded to include TR-FRET, HTRF®, BRET, dual luciferase reporter assays with injectors, and western blot detection.
With optimized reagents, option to operate the readers using the touchscreen or a computer, and industry-leading SoftMax® Pro Software, the readers provide an all access pass for breakthrough research.
QuickSync
- The Quick Sync feature pushes data to any computer within the same network and delivers data in an Excel-compatible format.
Automatic filter identification
- Using NFC tags, the SpectraMax iD5 reader automatically detects the wavelength properties of each filter in addition to the filter slide configuration, eliminating confusion and the need for manual information entry.
Hybrid optical system
- The SpectraMax iD5 reader provides the flexibility to set up experiments using filters, or a monochromator in 1 nm increments, or a hybrid mix of monochromator and filter-based wavelength selection.
Flexible temperature control
- Simple-to-use temperature control adjusts the experiment's conditions from ambient up to 66°C.
Flash assays captured with ease
- The SpectraMax Injector System with SmartInject® Technology features low dead volume (10 µL), overflow protection, and ensures equal mixing across the plate for high-precision experiments.
