Siemens - Somatom Sensation
Performance in CTLeading healthcare institutions and clinical experts trust SOMATOM Sensation’s excellent performance in both daily routine and clinical research. The 40- and 64-slice configurations of our award-winning SOMATOM Sensation demonstrate leadership in innovative technology and clinical applications. The result: an amazing success story with the industry's largest installed base of 64-slice CT systems worldwide.
FORUMSView All (21)
1Replya year ago | Siemens - Somatom Sensation SIEMENS SOMATOM EMOTION I have a problem when recording the studies on a DVD drive, the problem is the following: mistake. Could not write to CD or DVD. DVR-R locked until ejected by software. I would appreciate any information regarding these two errors. thank you Reply |
5Replies2 years ago | SOMATOM 64 HI. I HAVE A SIEMENS SOMATOM SENSATION 64 SLC . IT HAVE A ERROR: ROTATION MOTOR BLOCKED. THEY ALREADY BALANCE THE CT AND CHANGE THE BOARD "LIB' BUT CONTINUE WHIT THE SAME ERROR. I WILL APPRECIATED YOUR HELP. THANKS.Reply |
0Replies3 years ago | SSQ error Siemens Sensation 64 CT... 393 CT_SSQ SsqMeas : Timer could not be removed. Probably the timer hit already (timeout?) ---- What "timer" is being referenced? Reply |
SERVICE COMPANIESView All CT Scanner Companies
VIDEOS
Industry's largest installed base worldwide Industry's largest installed base worldwide - World's leading healthcare institutions and clinical experts have selected the SOMATOM Sensation. They trust the system's excellent clinical performance that enables them to deliver the highest level of patient care and maintain their positions as top service provider. Invest in the future and be part of this elite group. 'Zero Delay' CT Workflow The SOMATOM Sensation Web Selection is designed to bring today's CT workflow to a new level. Our 'Zero Delay' features enable a streamlined CT Workflow from patient preparation to diagnosis. Our proven WorkStream 4D concept for example, automatically reconstructs multi planar images, giving you additional valuable information with 'Zero Delay'. syngo WebSpace, another example of 'Zero Delay', connected via a fast data link* to the scanner image reconstruction system provides 3D volume data anytime, anywhere for multiple physicians simultaneously. This means instantaneously additional information right at the place where it is needed, for a fast and reliable diagnosis. A Leader in Clinical Applications SOMATOM Sensation brings together high-end CT imaging and cutting-edge post-processing capabilities. For example in cardiac imaging you will not only benefit from industry’s fastest rotation time of 0.33 seconds but also from our comprehensive syngo Circulation software, giving you all you need for evaluation to reporting. Partnership Beyond the Scanner With Siemens you not only invest in a excellent CT solution, moreover you enter a partnership with us and thousands of leading SOMATOM Sensation users worldwide. For us, partnership means to grow together. Participate in our leading educational programs and get direct hands-on experience of our well renowned customers. Partnership also means to keep you and your investment always on the leading edge. Feel what it means to live a real partnership and join the exclusive SOMATOM Sensation members club.
Ultra high isotropic resolution ----- 0.24 mm* z-Sharp Technology------------ yes Industry’s highest routine isotropic resolution at any scan speed and any position within the scan field ----------0.33 mm Maximum table speed with submillimeter resolution ---- 87 mm/s Industry's fastest rotation time -------- 0.33 s* Data acquisition (slices/rotation) --------------64 0 MHU STRATON X-ray tube--------------yes 5 MHU/min cooling rate Generator peak power ---------------------80 kW High Performance CT Clinical Engines* syngo CT.3D ------------------------------yes CT Oncology Engine ------------------------------yes CT Neuro Engine -------------------------------yes CT Cardiac Engine ------------------- yes, standard CT Acute Care Engine -------------------------yes syngo Clinical Applications* -------------------------yes CARE Solutions* -----------------------------------yes syngo WebSpace incl. Fast Data Link ---------------------------standard z-Sharp Technology See the Difference The revolutionary z-Sharp Technology has been designed to provide CT imaging with previously unknown sharpness, diagnostic detail, clarity and speed. •Previously unachievable image quality with up to 64 slices per rotation •Unprecedented diagnostic detail with the industry’s highest isotropic resolution of 0.33 mm voxel size - at highest volume coverage, at any position within the scan field - without increase in dose •Previously unknown sharpness and clarity with complete spiral artifact elimination z-UHR* (z-Ultra High Resolution) With our proprietary z-UHR Technology, we are pushing the boundaries of spatial resolution even further. For ultra-high resolution bone imaging, such as wrists, joints or inner ear studies, z-UHR provides unparalleled 0.24 mm isotropic resolution – until now only seen with research flat-panel and Micro CT technology. STRATONTM x-ray tube A paradigm shift in X-ray tube technology •Up to 0.33 s gantry rotation speed for cardiac and whole-body imaging •High-speed, high-resolution submillimeter volume scanning (up to 87 mm/s) •Premium image quality for all patient sizes •Elimination of cooling delays maximizes patient throughput •One-year full warranty, not limited by scan-seconds or patient volume •Typically significantly longer tube life reduces life cycle cost CARE Dose4DTM Our fully automated dose management system CARE Dose4D gives you the unparalleled combination of maximum image quality at minimum dose. The tube current is adapted in real-time and according to the anatomy of each individual patient’s organ, thus reducing dose of up to 68%**.
