Siemens - Somatom Emotion
by Siemens
The Siemens SOMATOM Emotion 16 CT machine obtains top quality images with minimal life-cycle cost. By purchasing a refurbished Siemens SOMATOM Emotion 16 CT scanner, you will enable your clinic to provide a wide range of clinical applications tailored to your business development needs.
Powerful and cost-effective, a used Siemens SOMATOM Emotion 16 CT scanner features a 70cm aperture, a 50cm scan field and a patient table that can hold patients up to 440 pounds. Offering reconstruction on the fly with up to 16 images per second, the Siemens SOMATOM Emotion 16 CT performs both routine and detailed, high resolution exams with ease.
6Replies2 months ago | Repeating last scan.... Need help with this error in somatom emotion duos Reply |
1Reply2 months ago | CB-Doc or Service Manual Does anyone know where I can find CB-DOCs for Emotion Duos (2003)Reply |
0Repliesa year ago | CE CERTIFICATE Im looking for the CE Certificate of that System Model Reply |
Gantry (Max. Clearance) | 70 cm |
Maximum Scan Range | 153 cm |
Patient Weight Capacity | 450 lbs |
Slices | 16 |
Type (configuration) | Multislice |
