Soma Technology - Codman Malis CMC V
by Soma Technology
Electrosurgical Unit (ESU)
The Codman Mails CMC V is a bipolar Electrosurgical Generator that offers Dual Wave Technology. The Dual Wave is where you can view both the cutting wattage and Coagulation wattage at the same time. This technology helped deliver precise control in power and irrigation. The Codman Malis comes with a large color display, on-screen controls, and knobs for controlling the cutting and the coagulation modes. The CMC V uses Asynchronous, Aperiodic waveforms that can be used with ultra-low output to help deliver a consistent control during coagulation.
-spectrum57
2 years ago
touchscreen
Touchscreen doesn't respond, does anybody have a service manual?
Equipment: Codman Malis CMC V
  • Proven DUAL WAVE Technology
  • CUT and COAGULATE with confidence using the proprietary Malis 1 MHz, Aperiodic, Asynchronous Waveform
  • Programmable User Profiles
  • Convenient storage of up to 8 generator settings by  procedural or surgeon preference
  • Enhanced Bipolar Outputs: Independent bipolar outputs allow for enhanced cut and coagulation functionality
  • Dedicated Rotary Control: Direct control of both CUT and COAG functions
  • Touch Screen Technology: Intuitive touch screen interface allows for the convenience of swift function changes
  • Oversized Color Screen: Information is bright and easy in all lighting conditions
  • Platform-Compatible  Consumables: No new codes or additional training required to use consumables
  • BIPOLAR CUT and COAG Modes: No requirement for separate equipment to perform CUT and COAG functions
  • Height: 8 in ( 20.3 cm)
  • Width: 13.75 in (34.9 cm)
  • Depth: 16.5 in (41,9 cm)
  • Weight: 13 lbs (5.9kg)
Enviromental Specifications
  • Operating Temperature: 50 – 104°F /10 – 40°C
  • Transport Temperature: -4 – 122°F /-20 – 50°C
  • Storage Temperature: -4 – 122°F /-20 – 50°C
  • Operating Relative Humidity: 20% to 90%
  • Transport Relative Humidity: 0% to 95%
  • Storage Relative Humidity: 0% to 90%
  • Operational Atmospheric Pressure: 700 hPa to 1060 hPa
  • Transport Atmospheric Pressure: 500 hPa to 1060 hPa
  • Storage Atmospheric Pressure: 500 hPa to 1060 hPa
