Sterilizers/Autoclaves
The SciCan STATIM 2000 G4 autoclave is designed to provide a complete sterilization solution for unwrapped and wrapped instruments. The STATIM 2000 G4 provides rapid sterilization balanced with rapid drying. This autoclave uses a combination of forced filtered air and convection heat to dry the instruments. It uses the heat generated by the sterilization process to dry the instruments.
- Sterilizes handpieces and instruments for immediate use in as little as 6 minutes.
- Thin stainless steel walls of the STATIM’s fully-removable cassette, allow for rapid heating and cooling of the chamber.
- Uses convection heat to dry instruments be utilizing the remaining heat in the system after a sterilization process.
- Can connect and send information to your smart device so you can have cycle data, instructions, and maintenance notifications.
Machine Dimensions
- Height: 6.2” (15.7 cm)
- Width: 16.3” (41.4 cm)
- Depth: 19.6” (50 cm)
- Weight: 46 lbs (21 kg)
Cassette Size (External)
- Height: 1.6” (4 cm)
- Width: 7.7” (19.5 cm)
- Depth: 16” (41 cm) (Including handles)
Cassette Size (Internal)
- Height: 1.4” (3.5 cm)
- Width: 7.1” (18 cm)
- Depth: 11” (28 cm)
General
- Sterilization Chamber Volume: 61 fl. oz. (1.8 L) U.S.
- Reservoir Volume: 140 fl. oz. (4.0 L ) U.S.
- Maximum Steam Temperature: 280ÚF (138ÚC)
- Maximum Operating Pressure: 49.5 psia (341kP abs)
- Ethernet Port: 10/100 Base-T
- USB Port: USB 2.0
- Protection Class: I
- Protection: covered (indoor use only)
- Ambient Operating Temperature and Humidity: 59ÚF to 77ÚF (15ÚC to 25ÚC) and 25% to 70%
- Max. Altitude: Up to 6600 ft (2000 meters)
- Installation Category: 1
