SciCan - STATIM 5000 G4
by SciCan
Sterilizers/Autoclaves
The SciCan STATIM 5000 G4 autoclave is designed to provide a complete sterilization solution for unwrapped and wrapped instruments. The STATIM 5000 G4 provides rapid sterilization balanced with rapid drying. This autoclave uses a combination of forced filtered air and heat to dry the instruments. The heat from the sterilization process is absorbed by unique drying plates located in the sterilization chamber. Its then transferred from the drying plates to the instruments utilizing radiant heat.
  • Sterilizes handpieces and instruments for immediate use in as little as 9 minutes.
  • Thin stainless steel walls of the STATIM’s fully-removable cassette, allow for rapid heating and cooling of the chamber.
  • Uses radiant heat to dry instruments be utilizing the remaining heat in the system after a sterilization process.
  • Can connect and send information to your smart device so you can have cycle data, instructions, and maintenance notifications.
Machine Dimensions
  • Height: 7.5” (19 cm)
  • Width: 16.3” (41.4 cm)
  • Depth: 23.6” (60 cm)
  • Weight: 73 lbs (33 kg)
Cassette Size (External)
  • Height: 3.2” (8 cm)
  • Width: 7.7” (19.5 cm)
  • Depth: 19.5” (49.5 cm) (Including handles)
Cassette Size (Internal)
  • Height: 3” (7.5 cm)
  • Width: 7.1” (18 cm)
  • Depth: 15” (38 cm)
Extended Cassette Size (External)
  • Depth: 22.2” (56.5 cm) (Including handles)
Extended Section (Internal)
  • Height: 1.1” (2.8 cm)
  • Width: 5.1” (13 cm)
  • Depth: 4.3” (11 cm)
