Beckman Coulter - Avanti JXN-26
Centrifuge
Experience simplified high-throughput sample processing and more control with the Avanti® JXN-26. Rely on the powerful features, improved imbalance tolerance, and quiet performance.
The Avanti JXN-26 stands out with these enhanced features:
- Monitoring and control flexibility with MobileFuge
- Advanced, easy-to-use data management
- Ergonomic design
- Intuitive interface
Data Management Provides Traceability
- Ideal for supporting numerous protocols in shared labs or GMP environments
- Utilize data logging and real-time run graphing
- Password protection for up to 50 unique user profiles
- Network multiple instruments
- Set up and store numerous protocols
Application Versatility
- Temperature control is optimized ensuring sample quality and avoiding unwanted artifacts
- Compatible with an extensive library of rotors, including fixed-angle and swinging bucket
- Adaptable for numerous application and workflow needs – includes BioSafe system providing operator safety and sample protection
- Broad labware range including Harvest Liners provide a complete sample protection solution.
Safe and Sustainable
- Dynamic Rotor Inertia Check (DRIC) and rotor recognition provide redundant safety checks to assure no rotor can be run above its rated speed
- High-torque, Switched Reluctance (SR) drive cycle shortens cycle times
- Uses less energy than traditional centrifuges
Easy to use software
- Simultaneous display of set and actual run conditions
- Rotor selection by name (not code)
- 11 acceleration/12 deceleration rates
- Delay start
- Run times to 99:59, Hold, and ω2t integrator for applications requiring precise reproducibility
