Siemens - Somatom Spirit
by Siemens
Join the World of CT
The difference that makes SOMATOM Spirit your first choice-New technology, more performance, less cost. [list] [*] The SOMATOM Spirit is a Multislice CT scanner for all who dreamed about an affordable and reliable system with the absolute newest, future-oriented technology. [*] SOMATOM Spirit is a sub-second, Multislice CT scanner adapted specifically for economical day-to-day clinical routine. [*] From the minute you take delivery of your new SOMATOM Spirit, you will benefit from its low-cost concept. Minimum space requirements, installation within one day, air cooling, and a very impressive cost/performance ratio assure life cycle profitability. [/list]
FORUMSView All (15)
-Aju George 93
Thu Apr 14 2022
Reference data is missing from the database
While trying to transfer a particular image from the system i am getting an error "reference data is missing from the database" remaining studies are transferring successfully ... How to solve this problem... Any help is appreciated.... Thanks Aju GeorgeReply
-Evansky
Tue Apr 13 2021
Service manual
Hi guys can I request for a service manual for siemens somatom spirit, my email add regoier.enterprise@gmail.com. ThanksReply
-IASIS
Mon Jun 15 2020
Problem
No scans at all message ssqerror and tube tokeranceReply
VIDEOS
Siemens Sensation CT 4 part se...
[list] [*] Increased volume coverage with gantry rotation speed of up to 0.8 seconds. [*] Small diagnostic details with collimated slice width down to 1 mm. [*] High power reserves with up to 40 kW generator and 3.5 MHU tube are especially useful with corpulent patients. [*] Wide range of clinical applications tailored to your needs. [*] Easy user interface provides simplicity and a short learning curve, even for less experienced users. [*] Fast image reconstruction of up to 5 images/s. [*] Highest possible image quality while maintaining low dose with CARE Dose4D (up to 68 % dose reduction). [/list]
Type (configuration)Multislice
SlicesDual
Maximum Scan Range153 cm
Gantry (Max. Clearance) 70 cm
