Air Cleaner
MET ONE 6000 air particle counters are a compact design with flexible sizing, flow rate and communication options that address the specific needs of cleanroom environments within the pharmaceutical, semiconductor, hard disk drive and flat panel display industries providing ISO 21501 accuracy for continuous particle monitoring. Reduce initial installation cost with MET ONE 6000P remote air particle counter’s integrated multi-parameter measurements.
- Built-in vacuum pump
- Industry leading particle counting on-line reliability
- Flexible for all your remote air particle counter applications
- Provides particle counts at 0.5µm and 1.0 cfm flow rate
- Long life laser diode for guaranteed continuous monitoring.
- Easy to integrate with any facility monitoring system
- Open architecture design to communicate seamlessly with your system
- Count alarm and alerts enable visual notification via built-in status lights.
- Optional relative humidity and temperature probe integrates RH/T data with particle count data in same data stream.
- In compliance with 21 CFR Part 11, FDA cGMP, and EU GMP Annex 1
Performance
- ISO 21501-4 unit-to-unit accuracy & reproducibility
Industry Standards
- ISO 21501-4 , ISO 14644-1:2015, FCC, CE
Light Source
Coincidence Loss
- 10% at 20,000,000 particles/m³
Sample Volume
Throughput
