NuAire - AireGard NU-140
by NuAire
Air Cleaners
The AireGard™ NU-140 generates HEPA-filtered vertical laminar airflow to provide product protection for sterile but non-hazardous drug compounding or non-hazardous work in microbiology and research labs. The DC ECM motor draws air through a pre-filter and propels it through a HEPA filter to create an ISO Class 5 level of air cleanliness inside a work zone surrounded by stainless steel walls and a work surface made of stainless steel with a PVC core. One easily monitors workbench performance through the Aeromax™ control system that visualizes pressure in the internal airflow plenum. The work zone comes standard with cord-pass throughs and fluorescent lighting but can be optionally configured with polycarbonate walls, an IV bar, LED lighting, outlets, and service valves to meet the demands of your pharmacy or lab’s workflow. It is the only model that can be fitted with a UV light and sliding window.
AEROMAX CONTROL SYSTEM
ULTRA HIGH EFFICIENCY MOTOR
HEPEX FLEXIBLE AIR PLENUM
