Sakura - Tissue-Tek Cryo3
by Sakura
Cryostat
Tissue-Tek Cryostat is precise and provides superior sections from 1 µm to 99 µm in 1 µm increments with 360° specimen orientation. A 240 x 64 pixel graphic LCD provides a visual display of critical information such as current chamber temperature, section thickness, and trimming thickness while 5 function keys enable easy modification of parameters.
FORUMSView All (24)
-Tom B
2 months ago
Will not boot up
Turned unit off then back on it will not boot up
Equipment: Cryo3 flex cryostat sakura
-Garrobo
9 months ago
Need service manual
I have the Cryo3 Plus service manual but this machine is different. is is showing an Err:07 configuration error, I need the service manual to find out what it is.
Equipment: Sakura Tissue-tek Cryo3 FLEX
-Linda M
3 years ago
Operating Manual
I am unable to view manual. asks me to sign in.Reply
  • No exposure to liquid toxic chemicals or residue inside chamber
  • Rapid disinfection within 75 minutes
  • Vacuum debris removal system standard with disinfection feature
  • Anti-roll rake for easy specimen transfer to slides
  • Cryomold® method and direct method can be used simultaneously
  • Cryo+® area cools to -50°C in as little as 5 minutes
  • Centimeters (W x D x H): 60 x 75 x 118
  • Inches (W x D x H): 23.5 x 29.5 x 46.6
  • Weight (with microtome): 176 kg (387 lb)
