NuAire - Blizzard HC NU-99420J
Biomedical Freezer
The Blizzard™ chest ultra-low freezer efficiently stores samples by using HC refrigerants and protects them within a structure using steel walls and composite insulation. The ergonomic design facilitates easy access, while the front electronic control panel clearly visualizes running parameters at all times and includes a USB port for long term datalogging.
SERVICE COMPANIESView All Biomedical Freezer Companies
ELECTRONIC CONTROL SYSTEM
- The electronic control system is placed at eye level for easy viewing and displays a clear readout of internal temperature, ambient temperature, and voltage during normal operation. If an abnormal situation arises, the panel activates an audible and visual alarm. Several indicator lights provide more detailed notifications about the freezer’s working condition, alarms, or maintenance needs. The easy to use navigation arrows and set key allow the user to create a pass code for access, choose a temperature set point, establish alarms limits, and configure a variety of other freezer preferences.
STANDARD FEATURES
- Temperature Range of -40°C to -86°CR290 and R170 Refrigerants
- Main Insulation with VIP and Polyurethane Foam
- Steel Exterior Walls
- Steel Interior Walls
- Electronic Control System
- Pass Code Protection
- Audible and Visual Alarms
- Battery Backup for Power Failure Alarm
- USB Download Port for Datalogging
- 2-INCH BOX CAPACITY 270
- RACK CAPACITY 27
- TEMPERATURE ACCURACY °C ±1
- TEMPERATURE CONTROL Microprocessor Controller
- TEMPERATURE UNIFORMITY °C ±5
