Weyer - Thermocare C/KCE
by Weyer
Infant Incubator & Warmers
The THERMOCARE device family is the result of decades of experience in heat therapy. It was designed as a cost-effective option for caring for infants requiring monitoring in the intermediate care area. The focus here was on the needs of the patient as well as the requirements of the user. THERMOCARE heated beds create an ideal, development-promoting and thermally stable environment for the little patient
THERMOCARE K
  • Heat bed with mattress surface heating, fixed height or height-adjustable
THERMOCARE C
  • Heat bed with radiant heater, fixed height or height-adjustable
THERMOCARE KCE
  • Heat bed with lying surface heating and radiant heater, height adjustable
  • The lying surface offers the best working conditions for the user. It can be tilted in both directions with one hand, whereby the patient always remains in the center under the radiant heater and is not exposed to temperature fluctuations. The distance to connected monitors and devices also remains the same.
  • Actively heated gel mattress
  • Gently adjust the correct lying height with the soft lift
  • Stable double smooth-running castors guarantee that the THERMOCARE heated bed stands securely and enables it to be moved easily
  • The close-meshed protective grille of the heater prevents you from touching the hot heating element.
