Weyer - Easy Care
by Weyer
Infant Incubator & Warmers
Warmth and the associated security is a basic need of every newborn child. Preheating lying surfaces and keeping them warm while being examined or changing diapers increases the well-being of small patients. With the Easy Care mobile examination and treatment table, we no longer create the necessary conditions at permanently installed care stations, but within a mobile unit. This enables spatial flexibility in a demanding everyday care routine. The particularly spacious lying surface of the Easy Care also makes it possible to change diapers and examine larger babies. At the same time, the compact design ensures that the required space is used optimally. For even more flexibility, the space required by the Easy Care and thus the spatial requirements for the place of use are minimized.
Noticeably pleasant radiant heat
The radiant heater's large-area lights ensure optimal lighting conditions when changing diapers or for examinations. The lighting intensity is dimmable and can be individually adjusted in 5 levels.
