Abaxis - Vetscan HM2
by Abaxis
Hematology Analyzer
The VetScanHM2 Hematology System is an impedance-based hematology system designed specifically for veterinary in vitrodiagnostic use. The VetScan HM2 provides a fully automated complete blood count (CBC) analysis of white blood cells, red blood cells, and platelets in whole blood in a veterinary setting. The system offers an 18-parameter CBC analysis, including a three-part WBC differential, and three cellular histograms.
-Robi
Fri Oct 27 2023
Service manual for hematology analyzer Abaxis VetScan HM2
Hello, do you have Service manual for hematology analyzer Abaxis VetScan HM2? Thank you for feedback. Robi
Equipment: hematology analyzer Abaxis VetScan HM2
  • Small sample size requirement: consumes approximately25 µl of EDTA-preserved
  • whole blood per CBC measurement.
  • Rapid test turnaround: only 2–3 minutes to results.
  • Advanced, integrated self-cleaning system for optimized performance with very minimal maintenance — expanded automatic aperture cleaning after every run.
  • Simple, intuitive, and easy-to-use software interface makes the analyzer very user friendly, and requires only a short learning curve.
  • Accurate results for out-of-range values: automatic calculations are provided for external
  • 1:5 dilutions in cases of extremely high values or very small sample volumes.
  • Simple, flexible database with large storage capacity:
  • Automatically saves up to 1,000 test records.
  • Data can be downloaded to a USB flash drive or a compatible data-management system.
  • Quality control (QC) results (including Levy-Jennings charts) are stored in the instrument’s QC database for viewing and management.
  • User reminders for replacing the reagent pack and performing simple maintenance task
  • Integrated laboratory results: the HM2 canbe connected to a VetScan Chemistry Analyzer for integrated results reporting.
  • Advanced user features: Multi user mode, customizable normal range, and adjustable analizing strength
  • External printer interface USB
  • Built-in printer “Easy Paper Operation” built-in thermal printer
  • Display 240x128-dot, high-contrast, CCFL, backlit, graphics liquid crystal diode
  • Keypad 24 foil keys + START button
  • External keyboard Standard PS/2 or USB-compatible keyboard
  • Power supply External 12 VDC, 8 A power module
  • Power supply (input) 100/240 V, 50–60 Hz, 10 W stand by, 80 W operating
  • Operating temperature 59–86 °F (15–30 °C). Optimal temperature is 77 °F (25 °C).
  • Dimensions (W x D x H) 12.6 x 10.2 x 14.4 in (320 x 260 x 365 mm)
  • Net weight 26.4 lbs (12 kg)
