MAQUET - ALM-X'TEN
by MAQUET
Surgical Light
The latest generation of the X’TEN surgical light sets a new standard of illumination quality, comfort and operational efficiency. With premium features such as significantly reduced heat at the surgical site, an integrated ring of LEDs and an unique, cross-shaped design, the Maquet ALM-X’TEN Surgical Light is guaranteed to meet any surgical light need.
-Pablo64
Wed Oct 04 2023
Ceiling fixing
I have purchased this twin arm light but it has no ceiling fixing bracket. Can I purchase it. Can I get a manual on one of these
Equipment: Alm X-ten ceiling mounted light
  • Maximum illumination for minimum eye fatigue
  • Uniform light distribution
  • True color rendition
  • Highly efficient heat management system
  • Micro lenses and less shadows for a better view
  • Aerodynamically designed
  • Ergonomic handling
  • Remote control and communication
  • Highest hygiene standards
  • Display LCD display
  • Back up option Integrated battery charger and switch
Attributes
  • Diameter of lighthead (cm) 62.5
  • Illumination (small field)* (lux) 110,000
  • Diameter of small field* (cm) >25
  • Diameter of large field* (cm) >30
  • Color temperature (K) 3,500
  • Infrared filtration dichroic mirrors
Electrical Connections
  • Voltage at bulb terminal (V) 23.5
  • Number of 24 V / 100 W 2
  • Input voltage to 100-120 V / 220-230 V
  • Frequence (Hz) 50 / 60
  • Input voltage from 16-27 V
  • Energix power supply (V) AC+DC TRMS
  • Input voltage 100-120 / 220-230 VAC
  • Output voltage 16-27AC+DC TRMS
  • Frequency 50-60 Hz Power supply type
  • Secondary switching "MOS FET" type
  • Controls Keypads Max. distance for remote control 50 m through I2C bus
  • Battery pack dimensions 180 x 415 x 189 mm
