Getinge - Servo-Air Lite
by Getinge
Ventilator
As a turbine-driven ventilator with powerful battery backup, Servo-air Lite can be transported throughout the hospital without requiring compressed air or external power — ideal for patients who are striving to reclaim their independence as a vital step to recovery.
  • Servo-air ventilators are easy to use and adaptable to the needs of your patients in most clinical settings. The Servo-air platform features the same interface used on other Servo ventilators. The layout is intuitive, and supports patient safety and efficient clinician workflows.[1] When needed, the Servo-air ventilators provide detailed on-screen support, from pre-use check, to selecting modes and specific support settings.
  • The Servo-air ventilators are a turbine-based platform with the power and flexibility to perform in a wide range of clinical environments. This allows you to adapt the level of support to the dynamic needs of your patient, providing the right level of support at the right time. They offer an array of invasive modes and non-invasive support capabilities including High Flow therapy for pediatric through adult patients.
  • The lifetime of the turbine is validated to 50,000 hours, or 10 years. It is designed to be powerful yet responsive and quiet. The turbine is capable of generating adequate pressure and flow to support a wide range of patients.
  • The Servo-air ventilators are designed for low cost of operation, low maintenance, and maximum uptime. They do not require any proprietary consumables or external flow sensors, this includes patient circuits.
