Schaerer Mayfield - Axis 500
by Schaerer Mayfield
Surgical Table
The Schaerer AXIS is an universal table for all surgical disciplines. The Schaerer AXIS is the most successful product line. It is an operating table that has already proven its capabilities thousands of times and even today is one of the most used tables in the world because of its unique cantilevered column. The proven reliability of the Schaerer AXIS, associated with their outstanding flexibility and their uniquely functional design, are good reasons for many hospitals around the globe to opt for a Schaerer AXIS table.
Highest capacity for eccentric column table
  • Highest weight capacity of 220kg/485lbs for a cantilevered column table with 1450mm/57" X-Ray window. This means more safety for all kind of patient positions, all kind of operations, all surgical disciplines and a much more stable table.
Highest grade stainless steel table
  • Full Stainless steel without rubber cover on the column makes the table ideal from hygienic perspective.
Largest X-ray window in the market
  • Due to its very eccentric column design, highest X-ray window in market. No need for sliding! Copied often – never reached!
Highest Durability of hand control
  • Hand control design with several functions and LCD screen. Automatic system check show failures for first level service information without delay. Programming features, different language options, adjust “Level” position, additional check for connections.
Highest safety features
  • Schaerer AXIS 500-700 is additionally equipped with a second built-in panel controlled an independent circuit. If in an emergency situation the main system fails, the operating table can be controlled with the emergency panel.
Highest patient comfort
  • viscoelastic pads are electric conductive, silicon and phthalate-free, 69mm/2,7" high, Velcro free, Ultrasonic welded seams. Easy removable and attachable. Appropriate for long operations and heavy weight patients.
Highest flexibility
  • Axis is offered in different variations to fully comply with user’s needs.
