GE HealthCare - Respironics C5 Sidestream
by GE HealthCare
Electrocardiiograph (EKG / ECG)
The Respironics C5 Low Flow Sidestream CO‚ Module is engineered for precise ETCO‚ monitoring in diagnostic ECG and multi-parameter patient monitoring systems. Designed for use with sidestream CO‚ sensors and related medical equipment, this module utilizes advanced infrared absorption spectroscopy to deliver accurate, real-time CO‚ measurements for both non-intubated and intubated patients.
Featuring a low 50 mL/min sampling rate, the C5 module supports efficient sidestream sampling while maintaining fast response times and reduced signal artifacts. Its solid-state, contamination-resistant design minimizes exposure to patient secretions, significantly lowering maintenance requirements and overall cost of ownership.
Biomedical engineers benefit from its high durability, easy integration, and reliable long-term performance, particularly in ventilator applications and continuous monitoring scenarios. The module is compatible with modern patient monitoring platforms and can be easily interchanged with the Capnostat 5 Mainstream CO‚ Sensor, providing flexibility for diverse clinical environments.
Cost-effective, disposable sampling accessories and a robust mechanical design make the Respironics C5 a trusted solution for sidestream CO‚ measurement, ETCO‚ analysis, and advanced respiratory monitoring across healthcare settings. (Generated by AI)
Powered by Froala Editor
