MinXray - CMDR-2S-TMIL
by MinXray
Digital Detectors
Portability is crucial for military personnel, especially for the medical needs of our servicemen and women. The CMDR-2S-TMIL, a complete digital radiography system, offers superior image resolution for diagnostic imaging. This portable digital radiography system includes a tethered digital detector (DR) and laptop mounted on a two-wheel, stainless steel stand, providing easy and convenient transport of the entire system. The digital detector slips out of its onboard protective enclosure for use. The CMDR-2S-TMIL system is your complete, portable radiography solution wherever duty calls.
  • Rugged construction yet light and compact
  • Easily transportable between sites
  • Set up in less than 1 minute
  • Image acquisition in less than 10 seconds
  • Superior resolution
  • Comes packaged with a HF100HSTC Military Transport
  • System Net Weight: Approximately 149 lb (68kg)
MinXray HF120/60H PowerPlus™
  • X-Ray Output: 60-14 mA @ 40-120 kVDC, 0.6-212 mAs
  • Input Line Voltage: 100-260 VAC; 50/60 Hz
  • Total Filtration with Collimator: 3.2 mm AI Equivalent
  • Collimator: Collimare CPL-125-MX01-C LED
14 x 17 Digital Detector
  • Receptor Type: Csl TI (direct vapor deposition) + reflective coating
  • Pixel Pitch: 143µm
  • Pixel Matrix: 2984 x 2448 (approx. 7.3 million pixels)
  • Limiting Resolution: 3.7 lp/mm
  • Cycle Time: 4 sec preview image, 6 sec erase and ready
  • Data Output: Gigabit Ethernet
  • Environmental: High-shock tolerance and water resistant
  • Temperature Range: Operating: 10° C to 35° C (max) | Storage: -20° C to +70° C
  • Humidity: Operating & Storage: 10 to 90%.
  • Pressure: Operating: 70-106 kPa; | Storage: 50-106 kPa
  • Weight: 6.6 lb (3 kg)
