Omron - HBP-T105
Designed to provide ease of use for the clinician and comfort for the patient, along with high accuracy and reliability.Innovative and original, the new HBP-T105 vital signs monitor has been designed to provide ease of use for the clinician and comfort for the patient, along with high accuracy and reliability. The monitor’s many useful features include alarms, intervals, an angled display with large colorful LEDs for easy viewing, and more! The monitor features Colin NIBP technology and is customizable with a variety of other options to meet a wide range of clinical requirements.
SERVICE COMPANIESView All Blood Pressure Monitor Companies
[list] [*] Smart Inflation - Smart Inflation automatically determines patient-specific inflation pressures and controls the inflation rate, which results in a more comfortable measurement experience for the patient. [*] Alarms - Whether it is a disconnected probe or a patient’s measurement falls outside of the user’s pre-programmed range, the HBP-T105 will sound an audible alarm as well as display a visual indicator of the measurement that is an issue. [*] Automatic Interval Monitoring - Choose from a wide variety of timer intervals to automatically take timed blood pressure measurements. The user can select interval measurements ranging from continuous to every 180 minutes. [*] Memory - The HBP-T105 will store the last 400 measurements taken. With one simple push of a button, you can review previous measurements. Or, if your monitor is equipped with a recorder, you can print out all the records.
Height | 150 mm |
Length | 239 mm |
Weight | 3.6 kg |
Width | 239 mm |
Operating Time: 6 hours when fully charged, with no printing,
