DR Systems
This multipurpose x-room allows you to perform examinations with the image receptor inside the Bucky, or outside for direct projections such as weight bearing exams, on stretcher…Featuring an all-floor column, vertical or tilt Bucky, fixed or variable height table, Rad Series Pro is available in manual, auto-tracking, and automated versions. It can be used with cassettes (CR plates) DR and WIFI detectors. You can perform all your conventional radiology examinations.
- The movements of the C2RS tube holder column, longitudinal on a rail, lateral by a telescopic arm, and vertical, enable optimal positioning to perform many types of examinations.
- The rotations of the X-ray unit and the column +/-180° allow acquisition of images in all directions, on table, on wall bucky as well as directly on a stretcher.
- In the automated version, the column is equipped with a control console with touch screen to modify the exposure parameters as well as the adjustment of the stands such as DSI, incidence, collimation, filtration… while remaining close to the patient.
Wall bucky
- The wall bucky moves vertically to perform whole acquisition of the bones and pulmonary examinations with standing patient.
In auto-tracking or automated configuration, the movements of the tube are synchronized with the movement of the wall bucky.
