DR Detectors
The DR 24M detector supports an easy, vendor-neutral upgrade of your analog X-ray mammography modalities to Digital Radiography (DR). The cassette-sized detector is designed to fit in the 24×30 buckys standard to analog mammography.
High DQE and low dose
- The scintillator of the detector uses directly deposited CsI. Combined with the high resolution pixel pitch of 76 μm, it delivers the excellent image quality required for digital mammography examinations. The high Detective Quantum Efficiency (DQE) and pixel size support lower radiation dose for patients. In addition, the lossless AED feature of the detector is, due to the simultaneously sensing of the X-ray, not increasing the patient dose.
Cassette less workflow: faster and more efficient
- The DR 24M provides all the advantages of Direct Digital, while enabling you to maximize the use of your existing equipment. Part of Agfa’s DR Mammography solution, it includes the NX image acquisition workstation with MUSICA image processing.
