DR Detectors
With Agfa’s vendor neutral DR Retrofit Solutions, you can easily upgrade your existing X-ray unit to Direct Radiography (DR) while protecting your current investment. From X-ray rooms to mobile analog units, it only takes a moment to go DR!
Confidence: Robust reliable in more situations
- The panels’ IP67 waterproof rating and 1-meterdrop height resistance let you work confidently , while the temperature range of 0-40°C makes them ideal for specialized applications, such as veterinary or military. Finally, theWPA2-PSK cybersecurity helps you keep patient data secure.
Productivity: diagnose more patient in a shorter time
- DR Retrofit with Dura-line™ gives you the choice of one or two batteries: the outstanding battery autonomy of up to 15 hours operating time (with 2 batteries) keeps you going throughout a shift, on one charge.
