SonoScape - HDL-35E
by SonoScape
Light Source
HDL-35E uses an LED as the main lamp, which is both highly efficient and has a longer lifespan.
  • HDL-35E supports hot plugging, so you can quickly change scopes between examinations without turning off the system. This enables a smooth workflow and quick transition between procedures.
  • HDL-35E displays the remaining working life of the lamp on the front of the light source.
