SonoScape - HDL-330X
by SonoScape
Light Source
HDL-330X uses a xenon lamp. The color temperature of the xenon lamp approaches that of direct sunlight. Further, it features a high color rendering index which works hand in hand with the image processor, offering a great performance in image quality.
  • HDL-330X supports hot plugging, so you can quickly change scopes between examinations without turning off the system. This enables a smooth workflow and quick transition between procedures.
  • HDL-330X automatically dims or brightens to give the best level of illumination at all times. In addition, the illumination level can be adjusted manually via the light source control panel in case of need.
