Washers/ Decontaminator
The MAT LD50 and MAT LD60 washers thermodisinfectors are conceived to cover the needs of an efficient and professional washing and disinfection process within compact and reduced spaces, without reducing the quality of process, cycle time nor performance of the devices.
These models have been specially designed for instruments, baskets, clogs, baby bottles ad glassware.
- The MAT LD50 and MAT LD60 washers thermodisinfectors, with external dimensions of 600 mm x 850 mm x 605 mm, have a washing capacity up to 8 DIN 1/1 baskets in 4 levels.
- Wide range of complementary elements adapted to the needs of each installation
- Control panel with LED display
- Door locking system during wash cycles and automatic unlock at the end of the cycle
- MAT LD60 incorporates forced drying module with hot air and HEPA H14 filter
- Thermal disinfection and 54O measurement
- Integrated water softener and steam condenser
- 2 peristaltic dosing pumps and 2 water connections
