Tecan - D300e
by Tecan
Automation System, Laboratory
From small molecules in DMSO to biomolecules in surfactant-containing aqueous solutions, this convenient benchtop solution allows rapid delivery of picoliter to microliter volumes of your compound into your assay plate
Requiring almost no set-up time, it uses disposable Dispenseheads to minimize dead volumes and virtually eliminate the risk of cross-contamination, offering high quality, low volume dispensing for a wide range of applications.
Flexible Plate Maps
  • Create any plate map and dispense any dose in any well. Even randomize the plate with only one click! The Tecan D300e's software is so simple to use that one can create any plate map desired in only minutes!
Digital Titration
  • Use your time more efficiently in follow up studies. D300eControl software makes it easy to generate dilution series, leading to more precise determination of Hill slopes and IC50 values.
Enzyme Profiles
  • The Tecan D300e’s Enzyme Profile wizard makes it quick and easy to set up titrations using differing combinations of enzymes or substrates in aqueous buffers, and inhibitors or other small molecules in DMSO.
