Sterilizers/Autoclaves
MAXIMUM EFFICIENCY WITH MINIMUM % OF FORMALDEHYDE
The estimated 80 % speed increase combined with a sterilizing solution of only 2 % formaldehyde and high penetrability, positions the new 130LF® at the forefront of LTSF technology and makes it the perfect solution for multichannel/complex endoscopy sterilization.
SPEED
- 12 kg treated in 90 min!
- This cycle time turns the 130LF® sterilizer into the fastest on the market.
PENETRABILITY
- The penetrating power of the 130LF® sterilizer makes it possible to sterilize complex, multi-channel cannulated instruments up to 3 m in length and 0.5 mm in internal diameter.
GENTLE WITH INSTRUMENTS
- LTSF technology is more delicate with instruments compared to other low temperature sterilization systems.
STERILIZING SOLUTION EXPIRY DATE
- The e-bag® sterilizing solution has a shelf life of 36 months! For greater flexibility in inventory management.
SAFETY
- Safe handling of the sterilizing solution. 2 % formaldehyde only. Integrated osmosis system for an optimal rinsing.
DESIGN
- Modern and minimalist design to facilitate the cleaning process.
