3M Health Care - Steri-Vac 5XL
by 3M Health Care
Sterilizer
A dual-cycle, 100% ethylene oxide (EO) gas sterilizer/aerator with a 4.8 cubic foot chamber. It can be installed in a wall or placed on a freestanding rack. Includes upper and lower baskets, and installation kit. A local exhaust hood is available. Its aeration cycle begins automatically after sterilization and a built-in printer records chamber temperature and vacuum, cycle number, temperature selected and aeration time for each load. Error and caution codes display if the cycle is interrupted. The 5XL can be installed in-wall or placed on a free-standing stacking rack. Upper and lower baskets are included. A local exhaust hood is available for the model 5XL, as well as "Two-Door Pass-Through" feature for clean room applications.
FORUMSView All (32)
-yoleida
Mon Jun 08 2026
Errores 21,22,23,y 52 Sterivac 5XL
Buenos dias alguien sabe de los erroes 21,22,23 y 52 Sterivac 5XL y del manual de reperacion
-Zihni
Thu Jun 04 2026
E73 Hatasi
Gaz otoklavi programdayken E-73 hatasi veriyor ve sicakligini 37 dereceye düsürüyor ne yapmam gerekiyor.
Translation:
The gas autoclave displays an E-73 error and drops its temperature to 37 degrees while running a program; what should I do?
-Guille Berna
Wed Jun 03 2026
Calibración de sesnor de presión y reseteo
Buen día. Estoy reparando este equipo el cual indica 960mbars a presión admosférica y necesito ajustarlo. Quizás por esto me da algunos errores relacionados al vacio final.
  • Modelo: 487AGP
  • Serial: 702519
  • Firmware: PR5.4
  • Necesito Master Code para calibración de sensor de presión
    Agradecería me puedan ayudar. Muchas gracias
Translation:
Hello. I am repairing this unit, which reads 960 mbar at atmospheric pressure, and I need to adjust it. This may be the cause of some errors I am getting regarding the ultimate vacuum.
  • Model: 487AGP
  • Serial: 702519
  • Firmware: PR5.4
  • I need the Master Code for pressure sensor calibration.
    I would appreciate your help. Thank you very much.
  • Ethylene oxide is a proven, efficacious sterilant offering maximum assurance that instruments are sterilized
  • With relative humidity monitor.
  • Built-in aeration begins automatically after sterilization and reduces potential for EO exposure.
  • Constant vacuum for operator safety.
  • No CFCs or HCFCs mean a low temperature sterilization system that's compatible with the environment
  • Low cost per cycle offers cost-effective means of low temperature sterilization.
Chamber Volume4.8 cu. ft.
Chamber Width38 in
Chamber Height15 in
Length 6.5 in
OrientationFloor Standing
Power Requirements220 VAC
Weight280 lbs
Chamber Depth32.5 in
  • Basket Dimensions: 16" x 31-1/2" 8"
