Washer/Decontaminator
Its tight dimensions and its manual hinged doors make it the ideal solution to facilitate the material reprocessing in small rooms.
The MAT LD100 washer thermodisinfector has a capacity up to 8 DIN 1/1 baskets in 4 level with a compact external dimensions of only 600 mm x 1810 mm x 705 mm.
- Door locking system that prevents simultaneous opening in the 2-door versions.
- Fully integrated graphic display.
- Ergonomic loading height.
- Low noise level.
- Installation under NULLGAP format, that allows to install up to 3 MAT LD100 washer thermodisinfectors in 2 meters wide.
- Minimization of water and energy consumption, achieving cost savings per cycle and an increase in daily productivity.
- Thermal disinfection and A0 measurement .
