Hach Company - DR6000
by Hach Company
Ultraviolet/Visible
The DR6000™ is the industry’s most advanced laboratory spectrophotometer for water testing. It offers high-speed wavelength scanning across the UV and Visible Spectrum, and comes with over 250 pre-programmed methods including the most common water and environmental testing methods used today. With optional accessories allowing for high-volume testing via a carousel sample changer, and increased accuracy with a sample delivery system that eliminates optical difference errors, this instrument ensures you are ready to handle your wide-ranging water testing needs.
  • The DR6000 has the most pre-programmed testing methods, including high-speed wavelength scanning across the UV and Visible Spectrum.
  • A carousel sample changer allows up to seven sequential measurements. The Sipper Module, an instrument-controlled sample delivery system, increases precision by constant optical characteristics.
  • The DR6000 comes with integrated QA software for scheduling, documenting and interpreting all of your needed quality measurements.
Data Logger
  • 5000 data points (result, date, time, sample-ID, user-ID)
Display
  • TFT 7 inch WVGA color touch
Enclosure Rating
  •  IP20 with closed lid
Interfaces
  •  USB type A (2), USB type B, Ethernet, RFID module
Manual Languages
  •  en, es, fr, ja, ko, pt, zh
Operating Conditions
  • 10 - 40 °C, max. 80% relative humidity (non-condensing)
Operating Mode
  •  Transmittance (%), absorbance and concentration (wavelength, time)
Optical System
  • Reference beam, spectral
