NeuroWave - NeuroSENSE OEM
by NeuroWave
Modules
The NeuroSENSE OEM Module is an innovative and economical solution designed for third-party patient monitors seeking to incorporate depth-of-anesthesia (DoA) or sedation monitoring capabilities. Engineered with a rugged and compact design, the NeuroSENSE OEM Module provides hospitals, biomedical engineers, and medical professionals with high-resolution EEG signals and processed depth-of-anesthesia variables for enhanced patient monitoring. (Generated by AI)
  • Depth-of-Anesthesia & Sedation Monitoring: Provides precise and reliable monitoring of anesthesia depth or sedation levels for patient safety.
  • High-Resolution Bilateral EEG Signals: Delivers accurate EEG data for better analysis of anesthesia or sedation effects.
  • NeuroSENSE Processed Variables: Offers processed variables for in-depth analysis, allowing for optimized sedation and anesthesia management.
  • Economical Design: An affordable solution for third-party patient monitors integrating depth-of-anesthesia monitoring.
  • Direct Serial Interface Power: The device is powered directly through its serial interface, ensuring seamless integration with compatible monitors.
  • Optimized for Signal Quality: Designed for use with the Electrode Kit EK-901, ensuring high-quality, reliable signal acquisition for accurate monitoring.
  • Rugged and Compact Package: Built to withstand the demands of the clinical environment while maintaining portability and reliability.
The NeuroSENSE OEM Module offers an ideal solution for biomedical engineers and healthcare professionals who require reliable depth-of-anesthesia monitoring without compromising performance or budget. Whether used in surgical settings, ICU, or other environments where anesthesia or sedation levels need to be carefully monitored, the NeuroSENSE OEM Module ensures optimal patient safety.Its easy integration with third-party monitors and excellent signal quality (with the Electrode Kit EK-901) makes the NeuroSENSE OEM Module a valuable tool in the clinical depth-of-anesthesia monitoring landscape. (Generated by AI)
  • Power consumption 0.8 W
  • Interface protocol: USB 2.0 and above
  • Electrode compatibility: EK-901
