CT Scanner
With Optima CT540, this design concept combines your clinical expertise with a streamlined workflow continuum to help you provide the most reliable and consistent imaging results.
Advanced applications
- Advanced applications help clinicians make a fast and confident diagnosis.
OptiDose
- Dose reduction with ASiR is combined with GE Healthcare’s proven OptiDose* technologies that deliver dose reduction at the source.
VISR
- Volumetric Image Space Reconstruction (VISR) are 3D filters that reduce image noise (standard deviation) without compromising spatial resolution to provide clear visualization in neuro and cardiac imaging, to deliver diagnostic image quality with potentially lower mA.
ASiR technology
- May allow for lower mA exams throughout the body.**
Dose check
- Prior to starting the scan, Dose check provides tools to notify and alert the operator setting the scan parameters whether the estimated dose index is above user-defined notification values. The Dose check feature is designed to comply with the NEMA XR-25-2010 standard.
