Andersen Products - EOGas 310
by Andersen Products
Andersen's EOGas system links our unique gas diffusion technology with advanced micro-processor control.
Andersen's EOGas system links our unique gas diffusion technology with advanced micro-processor control. The micro-processor keeps track of the bags in the sterilizer, and the operator may load new bags or unload finished bags while others are in process. For tracking purposes, when a bag is loaded, two labels are printed: one is placed in the log book, one is placed in the bag. Unique multi-load capabilities eliminate batch load restrictions. Innovative unit-dose cartridges match the actual load volume, greatly reducing gas consumption. Easy installation requires no compressed air or water source, only a dedicated outside vent and a single-phase AC outlet.
[list]    [*] Our multiload EOGas system adds and removes bags at any time while other bags are processing.      [*] Gas diffusion eliminates "dead space" around loads by delivering Ethylene Oxide directly to the load.      [*] No harsh preconditioning is required, treating sensitive products gently and effectively. Conventional systems fill the entire chamber with EO, possibly overdosing product to compensate for "dead space"around loads. Forced pre-conditioning in a deep vacuum under high humidity may damage sensitive products.    [/list]
Chamber Volume6 cu. ft.
OrientationFloor Standing
Weight245 lbs
Extractor Weight: 10 lbs     Exhaust Requirements: Dedicated 3” discharge vent     Power Requirements: 110/120 V, 50 Hz, 10.75 Amps, 50/60 Hz, 10.75 Amps (220/240 V, 50/60 Hz, 5.4 Amps)
