Villa Sistemi - Apollo DRF/OPEN
by Villa Sistemi
R/F Systems
Apollo DRF in its “Open” version is a premium digital remote controlled table that extends the diagnostic applications also to the interventional procedures thanks to the maximized access to the patient from every table’s side.
Patient’s care is maximized by different solutions that reduce the emitted dose, making it a versatile digital system suitable also for pediatric examinations. The acquisition system based on 43x43 cm dynamic Flat Panel detector allows to acquire every anatomic district, thanks also to special functions such as Digital Subtraction Angiography (DSA) and automatic Stitching.
Great versatility for radiographic applications
  • The use of one single detector for both fluoroscopy and radiography offers an unparalleled range of applications that includes all the most common general radiographic procedures, gastro-intestinal studies, tomography and vascular studies.
Maximum dose reduction
  • In addition to the low dose required by the high sensitive dynamic digital detector, different solutions can be implemented on the system to further reduce the dose to the patient during the exam.
Open tabletop structure
  • The Open design, based on a single-side suspended tabletop, grants a direct and easy access to the patient from all sides of the table. This configuration is particular useful during interventional procedures, because two or more operators can be at direct contact with the patient. The mechanical structure of the tabletop grants a patient weight capacity up to 230 kg without limitations on the table movements.
Wide range of fluoroscopy examinations
  • Fluoroscopy exams also take benefit from the large active area of the detector that allows visibility of larger anatomic regions without patient repositioning.
