Arthrex - AR-9600
by Arthrex
Electrosurgical Unit (ESU)
The Arthrex O.P.E.S. Electrosurgical Generator includes the latest technology. This unit offers unsurpassed performance, flexibility, reliability, and convenience.
1ReplyFri Sep 13 2024 | PM Checkout If anybody has a pm sheet for these units, please let me know Reply |
• Two Cut Modes,Cut I & Cut II Two cut modes give the surgeon flexibility to cut all types of tissue without losing performance. Cut I generates constant output power over a wide range of impedances.
• Blend with 10 Settings The Blend mode is a combination of Cutting and Hemostasis. The Arthrex O.P.E.S. Electrosurgical Generator gives the surgeon freedom to adjust the desired level of blend. A setting of 1 is minimal hemostasis with maximum cutting effect. A setting of 10 is maximum hemostasis with minimal cutting effect. This adjustment is easily achieved by an incremental adjustment.
• Presets The surgeon can store 10 user-defined presets for easy recall of frequently used settings. A selection of 10 factory set presets can be reset to your preferred settings.
• Two levels of coagulation: Pinpoint and Spray Pinpoint provides precise control of bleeding in localized areas. Spray provides greater control of bleeding in highly vascular tissue over broad surface areas.
• Return electrode sensing and contact quality monitoring The Arthrex O.P.E.S. Electrosurgical Generator incorporates a return electrode contact quality monitoring system (Bovie NEM™). This system detects the type of return electrode: solid or split. The system also continually monitors the contact quality between the patient and the split return electrode. This feature is designed to minimize patient burns at the return electrode site.
• FDFS™ (Fast Digital Feedback System) The FDFS™ (Fast Digital Feedback System) measures voltage and current at 5,000 times a second and immediately adjusts the power to varying impedance during the electrosurgical procedure. The unit’s digital technology senses and responds to changes in tissue and density. Unlike analog, this feature reduces the need to adjust power settings manually.
