ETC - EtO Sterilizer
by ETC
"Ethylene oxide sterilizer" is defined as equipment which uses ethylene oxide as a biocide to destroy bacteria viruses, fungus and other organisms.
"Ethylene oxide sterilizer" is defined as equipment which uses ethylene oxide as a biocide to destroy bacteria, viruses, fungus and other unwanted organisms. Ethylene oxide is used in sterilization of items that are heat and moisture sensitive.
-malungu
Thu Oct 01 2015
ETO GAS STERILIZER
We have ETO Gas sterilizer it shows error E10 Could some one get me the solution for this the water is full in the tank. i need service manual for it.
Thanks
[list]        [*] Sterilization basket of suitable size 1 No.      [*] ETO gas cartridges 25 Nos      [*] Compressed Air Plant      [*] Packing Material with Chemical Indicator of all sizes one roll each      [*] Sealing Machine Heavy Duty - 1 No.        [/list]
Chamber Volume7 to 10 cu. ft.
Sterilization gas: Ethylene oxide  Sterilization method: Cold sterilization of heat sensitive materials  Operating temp. Range: 40 to 75 C
