STERIS - AMSCO Eagle 3017
The Amsco Eagle 3017 EO sterilizer combines the needs of sterilizing heat and moisture sensitive items with the assurance of sterility.The Amsco Eagle 3017 EO sterilizer combines the needs of sterilizing heat and moisture sensitive items with the assurance of sterility in a safe and economical sterilization cycle. Supported by over a century of engineering excellence, the Eagle 3017 features an advanced microprocessor control system which monitors multiple parameters for each of the four pre-programmed cycles. The Eagle 3017-s 5 cu/ft chamber utilizes two convenient baskets for sterilization and aeration within one chamber. Further, the Eagle 3017 sterilization cycle operates entirely under vacuum with the added safety of a disposable EO cartridge placed within the sterilization chamber.
FORUMSView All (21)
0Replies2 years ago | perdida comunicacion buenas noches tengo un problema con mi equipo me sale la alarma comunicación con el host se ha perdido alguien me puede ayudar si le ha pasado, gracias anticipadasReply |
1Reply3 years ago | Steris ETO abator not coming up to temperature The abator for my 3017 Steris ETO sterilizer is not reaching temp, its stuck at room temp rather than the typical ~300F. Im looking for any ideas as to why. I have two identical units and neither will heat up. This just started occurring as it worked fine a couple of days ago Reply |
1Reply5 years ago | Necesito saber cómo resetear por completo un proceso Solo me marca gas en la cámara Escape y no sale de ahí ni reseteandoReply |
- Built-in Envirogard™ local exhaust system is a standard safety feature to remove any residual EO vapors when the door is opened.
- Eagle® 3000 Series advanced microprocessor control system monitors cycle parameters and ensures that sterilizer door(s) remain locked until cycle is complete.
- Preprogrammed sterilization cycles are easily selected with numbered touchpads
- Impact printer provides complete documentation that won’t fade over time.
Height | 73.7 cm |
Length | 94 cm |
Orientation | Benchtop |
Weight | 136 kg |
Width | 83.8 cm |
