NIDEK - YLC-500 / 500 VIXI
by NIDEK
Aesthetic Laser
The YLS-500 is a yellow wavelength laser photocoagulator fitted on a slit lamp and designed for photocoagulation, pan-photocoagulation, trabeculoplasty and iridotomy treatments. Two models are available, the Monospot simple YLS-500 (single impact) and the Multispot YLS-500 VIXI (laser impact grid). It can be fitted with a subthreshold treatment module, the LMP (Low Power Mode).
-Laserdude
Tue Mar 18 2025
Nidek MC 500/Vixi
Yellow 577nM not engaging.  Green and Red has good power.
When yellow is engaged , display says call Nidek Service.
Can anyone send a Service Manual or offer advise?  Anyone have experiance with this ophthalmic Laser?
  • 577 nm yellow photocoagulator laser
  • Monospot or Multispot laser system
  • Comes standard with a lifting table and an SL-1800 slit lamp
  • Can be fitted on a Haag-Streit 900 BQ (Monospot)
  • Easy to use through the control panel and the settable 3D mouse (Multispot)
  • 22 patterns are available (Multispot): up to adjustable shape, size and distance points
  • AutoForward mode with automatic positioning of the laser beam
  • Saving the treatment parameters (10 programs)
  • Saving the magnifications of the magnifying glasses
  • LMP option for subthreshold treatment
