FSI - CMS Tech
by FSI
CMMS Software
Promote efficiency, accuracy, and productivity with CMS Tech: a truly mobile CMMS app designed to empower every level of your organization.
Empower transparency
  • Guide your decision-making with 24/7 visibility across your Facilities and HTM maintenance operations.
Work from any device
  • CMS Tech is iOS agnostic so you can access your maintenance management data from any iPhone, Android, or Windows device.
Improve accuracy
  • Boost data reliability by logging work and updates from the field. Take and attach pictures to document work orders and assets—including damage and condition.
Simplify communications
  • Trigger notifications and emails to relevant parties when work orders are created, assigned, and completed.
Scan & find assets
  • Use your mobile device’s camera or a handheld barcode scanner to quickly identify assets, complete active work orders, and edit records.
Standardize data entry
  • Customize required fields across your asset and work order records to promote data reliability and reporting.
