Medtronic - Valleylab" FT10 Energy Platform
by Medtronic
Electrosurgical Monitors
The Medtronic Valleylab FT10 Energy Platform is an advanced electrosurgical generator designed to support a wide range of surgical procedures. The FT10 platform provides optimized vessel sealing performance with compatible LigaSure™ devices and uses high-speed, closed-loop control to continuously monitor tissue electrical properties. Its advanced vessel sealing algorithm delivers a proportionate amount of energy based on the composition and size of the vessels being sealed.
The FT10 features a simplified touchscreen interface, automatic power settings, bipolar cable compensation, software upgrade capability, and soft coagulation settings. Its automatic power settings help minimize setup and the need for additional handling during surgery. (Generated by AI)
  • Medtronic Valleylab FT10 energy platform
  • Electrosurgical generator for a wide range of surgical procedures
  • Optimized vessel sealing performance with LigaSure™ devices
  • High-speed, closed-loop tissue monitoring
  • Advanced vessel sealing algorithm
  • Proportionate energy delivery based on vessel composition and size
  • Simplified single touchscreen interface
  • Automatic power settings
  • Bipolar cable compensation for consistent electrosurgical output
  • Software upgradeable through Ethernet connection
  • Soft coagulation setting
  • Designed to minimize setup and handling during surgery
(Generated by AI)
SpecificationDetails
ManufacturerMedtronic
ProductValleylab™ FT10 Energy Platform
Product TypeElectrosurgical Generator / Energy Platform
SoftwareUpgradeable
ConnectivityEthernet connection; Wi-Fi capabilities present but not enabled
Bipolar Cable CompensationReads cable length and width for consistent electrosurgical output
DisplaySingle simplified touchscreen
ES SettingSoft coagulation
Power SettingsAutomatic power settings
Width36.8 cm
Depth46.2 cm
Height17.8 cm
Weight10.1 kg
Item NumberVLFT10GEN
Units per Box1
(Generated by AI)
