Thermo Scientific - Savant SPD1030-115 SpeedVac Integrated Vacuum Concentrator
by Thermo Scientific
The Thermo Scientific Savant SPD1030-115 SpeedVac Integrated Vacuum Concentrator is a medium-capacity laboratory vacuum concentrator designed for the efficient drying and concentration of aqueous and non-aggressive samples. This fully integrated SpeedVac vacuum concentrator provides convenient installation and programming for routine laboratory sample preparation.
The SPD1030-115 is well suited for concentrating and drying DNA and RNA precipitates, PCR samples, proteins, enzymes, and HPLC fractions in tubes or microplates. The system can be used with water, ethanol, isopropanol, and other organic solvents, making it a versatile solution for molecular biology, biochemistry, proteomics, and analytical laboratory workflows.
With capacity for up to 120 x 1.5 mL tubes, the Thermo Scientific Savant SPD1030-115 provides medium-capacity sample processing while supporting a variety of rotor configurations for different tube, vial, and plate formats. (Generated by AI)
  • Integrated vacuum concentrator for streamlined laboratory sample preparation
  • Designed for drying and concentrating aqueous and non-aggressive samples
  • Medium-capacity design for efficient sample processing
  • Accommodates up to 120 x 1.5 mL tubes
  • Supports up to 10 x 15 mL tubes
  • Supports up to 6 x 50 mL tubes
  • Accommodates up to 2 microwell plates
  • Compatible with additional rotor options for various tubes, vials, and plates
  • Suitable for DNA/RNA precipitates, PCR samples, proteins, enzymes, and HPLC fractions
  • Supports samples containing water, ethanol, isopropanol, and other organic solvents
  • Temperature range from ambient conditions up to 80°C
  • PTFE-coated aluminum chamber for laboratory use
  • Maximum vacuum of <10 Torr (13 mbar, 1.3 kPa)
  • 115 V, 60 Hz, 8 A electrical configuration
  • UL Listed for U.S. and Canadian requirements
  • CE marked
(Generated by AI)
SpecificationDetails
ManufacturerThermo Scientific / Savant
ModelSPD1030-115
Product TypeIntegrated Vacuum Concentrator / SpeedVac
CapacityMedium
Maximum Vacuum<10 Torr (13 mbar, 1.3 kPa)
Temperature RangeAmbient (17°C to 32°C) to 80°C
Chamber MaterialPTFE-coated Aluminum
Tube CapacityUp to 120 x 1.5 mL tubes
15 mL Tube CapacityUp to 10 tubes
50 mL Tube CapacityUp to 6 tubes
Microwell Plate CapacityUp to 2 plates
Rotor OptionsAdditional options available for tubes, vials, and plates
Power Requirements115 V, 60 Hz, 8 A
Dimensions26" W x 25" D x 16" H (66 x 64 x 41 cm)
Shipping Weight146 lbs. (86 kg)
CertificationsUL Listed (U.S. and Canada), CE Marked
IncludedVacuum concentrator only
(Generated by AI)
