Draeger - Babyloog VN600 Neonatal Ventilator
by Draeger
Neonatal Ventilator
The Dräger Babylog VN600 Neonatal Ventilator is a high-performance neonatal and pediatric ventilator designed to support respiratory care throughout the patient journey, from delivery to discharge. Developed for neonatal intensive care units (NICUs), the Babylog VN600 supports transitions between oxygen (O‚) therapy, non-invasive ventilation (NIV), and invasive ventilation.
Featuring a streamlined interface and a 15.6-inch capacitive glass touchscreen, the Babylog VN600 is designed for intuitive operation, efficient clinical workflows, and comprehensive patient data management. Its ventilation tools support individualized lung-protective strategies, while integrated connectivity based on the SDC standard supports interoperability with compatible medical devices.
The Dräger Babylog VN600 is designed for neonatal and pediatric respiratory care environments requiring versatile ventilation capabilities, monitoring features, and adaptable clinical workflows. (Generated by AI)
  • High-performance neonatal and pediatric ventilator for NICU use
  • Supports transitions between O‚ therapy, non-invasive ventilation (NIV), and invasive ventilation
  • Designed to support individualized lung- and brain-protective ventilation strategies
  • 15.6-inch capacitive glass touchscreen
  • Streamlined user interface with configurable controls and guided operation
  • Maximum inspiratory flow specification of 120 L/min
  • Pressure-controlled ventilation and spontaneous breathing support
  • Dräger Volume Guarantee feature
  • Smart Pulmonary View
  • CO‚ monitoring, loops, and trend data
  • Automatic Tube Compensation (ATC)
  • 30-minute internal battery
  • External battery support
  • 360° rotatable display and color-coded alarm light
  • SDC-standard connectivity for interoperability and secure alarm distribution with compatible devices
  • Designed to support intra-hospital patient transport with compatible system components
(Generated by AI)
SpecificationDetails
ManufacturerDräger
ModelBabylog VN600
Product TypeNeonatal Ventilator
Equipment CategoryRespiratory Care / Ventilation
Intended Patient CategoriesNeonates and pediatric patients
Maximum Inspiratory Flow120 L/min
Ventilation ModesPressure-controlled ventilation; spontaneous breathing support
Oxygen TherapySupported
Non-Invasive Ventilation (NIV)Supported
Display15.6-inch capacitive glass touchscreen
Internal Battery30 minutes
External BatterySupported
Serial InterfacesRS232, USB, LAN
Monitoring FeaturesCO‚ monitoring, loops, trends
Additional FeaturesSmart Pulmonary View, Volume Guarantee, ATC
ConnectivitySDC-standard interoperability
Transport CapabilityIntra-hospital transport with compatible components
(Generated by AI)
