UTAS - UVENT-A-S ICU
by UTAS
ICU Ventilator
The UTAS UVENT-A-S ICU Ventilator is an expert-class mechanical ventilator designed to provide protective respiratory support across critical care, intensive care, emergency care, and intrahospital transportation. The UVENT-A-S uses compressed gas-driven pneumatics, a microcontroller-driven pneumatic system, and an active PEEP valve for precise ventilation control. It is designed for adult, pediatric, and neonatal patients, with ventilation modes adapted to the selected patient category.
The UVENT-A-S combines a clinician-friendly touchscreen interface with advanced ventilation, monitoring, alarm, and connectivity capabilities. Features include intelligent adaptive ventilation modes, high-flow oxygen therapy, CPR ventilation, intubation support, SpO‚ and CO‚ monitoring, USB data export, and HL7 connectivity for healthcare information systems. The ventilator can also provide up to 4 hours of ventilation using a Li-ion battery, depending on configuration and operating conditions.
Designed for demanding clinical environments, the UVENT-A-S includes automated device and breathing-circuit self-tests, automatic compensation for altitude, compliance, leaks, and resistance, a durable aluminum case, and a permanent ultrasonic oxygen sensor. Multiple mounting options are available, including mobile trolley configurations and a universal VESA mounting plate. (Generated by AI)
  • Expert-class ICU ventilator for critical and intensive care applications
  • Compressed gas-driven pneumatic ventilation system
  • Microcontroller-driven precision pneumatic system
  • Active PEEP valve
  • Automatic inlet-pressure compensation
  • Supports adult, pediatric, and neonatal patients
  • Suitable for critical care, intensive care, emergency care, and intrahospital transportation
  • Clear, user-friendly touchscreen interface
  • Drag-and-drop touchscreen operation
  • Fast ventilation startup and quick access to parameters and alarm limits
  • AdVent and ProVent intelligent adaptive ventilation modes
  • Flow and pressure smart triggering
  • High-flow oxygen therapy (HFOT)
  • Helmet interface selection
  • CPR ventilation mode
  • Intubation support tool
  • AutoO‚ function for oxygen delivery based on SpO‚ target
  • Up to 100 monitored parameters and trends
  • Event log capacity of up to 10,000 records
  • SpO‚ and CO‚ monitoring options
  • USB export of screenshots and records
  • HL7 connectivity for HIS data export
  • Automated ventilator and breathing-circuit self-tests
  • Permanent ultrasonic oxygen sensor
  • Durable aluminum housing
  • Up to 4 hours of Li-ion battery operation
  • Multi-level audio-visual alarm system
  • Automatic altitude, compliance, leak, and resistance compensation
  • Multiple communication interfaces
  • Mobile trolley and mounting options
  • Remote service capabilities for diagnostics, adjustments, repairs, and software updates
(Generated by AI)
SpecificationUVENT-A-S
ManufacturerUTAS
ModelUVENT-A-S
Device TypeICU Ventilator / Mechanical Ventilator
CategoryRespiratory Support / Critical Care
Ventilation SystemCompressed gas-driven pneumatics
PEEP SystemActive PEEP valve
Control SystemMicrocontroller-driven pneumatic system
Patient CategoriesNeonatal, Pediatric, Adult
Clinical ApplicationsCritical Care, Intensive Care, Emergency Care, Intrahospital Transportation
Ventilation ModesMandatory, Interactive, Spontaneous, Intelligent, Special
Intelligent ModesAdVent, ProVent
High-Flow Oxygen TherapyYes
CPR Ventilation ModeYes
Intubation SupportYes
Helmet InterfaceSupported
Oxygen ControlAutoO‚ function
MonitoringUp to 100 parameters and trends
Event LogUp to 10,000 records
SpO‚ MonitoringYes
CO‚ MonitoringSide- or mainstream
Data ExportUSB
HIS ConnectivityHL7
BatteryLi-ion
Battery RuntimeUp to 4 hours
Oxygen SensorPermanent ultrasonic sensor
Self-TestingAutomated device and circuit self-tests
Alarm SystemMulti-level audio-visual
CompensationAltitude, compliance, leak, and resistance
HousingAluminum
Mounting OptionsMobile trolley, display mount, universal VESA plate
Remote ServiceDiagnostics, adjustments, repairs, software updates
Display OptionsAdditional 22" HD display compatibility
ConnectivityMultiple communication interfaces
(Generated by AI)
