Thermo Fisher Scientific - Shandon Cryotome FE and FSE
by Thermo Fisher Scientific
Microtome
Reduce turnaround time using rapid temperature response with the Thermo Scientific™ Cryotome™ FSE Cryostat. This fifth-generation instrument is adapted for multiple users and samples, with built-in operator comfort, and a superior knife holder design that allows the user to easily obtain quickly identifiable frozen sections. It features a spacious, easy-to-use chamber.
FORUMSView All (4)
-MedWrench Crystalyn
Tue Jun 01 2021
Thermo Shandon Cryotome FE
Thermo Shandon Cryotome FE Reply
-Robin1313
Fri Dec 11 2020
Error 1- no temperature control
Hi, I'm trying to change the "working temperature" and the message "error 1" comes up when I press the button. This error is "Err 1 denotes an invalid push-button entry, or if too many push-buttons are pressed simultaneously." But, I cannot change the temperature setting. Please help!Reply
3
-JohnArford
Thu Aug 22 2019
Manual Available??
Manual Available??Reply
VIDEOS
  • Microtome located outside of the cryochamber, making it easier and quicker to clean
  • Blade holder moves laterally, eliminating the need to unclamp and re-clamp blade and maximizing blade usage
  • Section thickness adjusts from 1 to 20μm in 1μm increments and 20 to 60μm in 5μm increments
  • Control chamber temperature from 0° to -35°C
  • Control cryobar temperature
  • Cool specimen rapidly to prevent freezing artifacts with cryobar refrigeration system that cools to -55°C
  • Cool from ambient to set temperature in as little as two hours
  • Overall D × W × H: 293/8 × 273/4 × 491/4 in. (74.5 × 70.5 × 125cm max.)
  • For width with handle, add 5 in. (12.5cm)
  • Working height: 413/8 in. (105cm max.)
  • Weight: 2751/2 lb. (125kg)
  • Electrical requirements: 115V 60Hz
