Belimed - WD290
Effective performance and drying of the automats WD230 / 250 / 290 is enabled by efficient conduit design and the powerful recirculation pump.Effective performance of decontamination, disinfection and drying of the automats WD230 / 250 / 290 is enabled by efficient conduit design and the powerful recirculation pump. The precision fitting rack docking device ensures that water is supplied to its optimum level, even when processing minimal invasive equipment.
3Replies4 years ago | Door operation Door stuck openReply |
0Replies7 years ago | Belimed WD 290 Both Doors Opening at the Same Time Hello, I am having an issue with my Belimed WD 290 washer. Both doors are opening at the same time when simply requesting only the load side door to open. Then to go back up each side needs to be pushed individually. I am curious if anyone has ran into this before and if there is something I am able to do about it? Thank you for your time.
Matt Reply |
•High throughput with a small footprint •Utilizes dynamic filling to use only the amount of water required per cycle based on load size •Economic design uses less water, energy and chemicals than competitors •Meets ISO 15883 for thermal disinfection •High volume / low pressure wash is gentle on instruments •Optional automation is available to optimize workflow and minimize staff error
Rack dimension (w x h x d) 610 x 670 x 750 mm 610 Water connection Cold water 3/4“ 200-600 kPa (2-6 bar) Hot water 3/4“ 200-600 kPa (2-6 bar) DI-water 3/4“ 200-600 kPa (2-6 bar) Drain connection DI 56 mm (DN50) Electr. connection 400V 3N AC, Power P 25kW (Fusing 40A) Exhaust air DA 115mm (DN100) connection 500m3/h Steam connection Saturated R 1/2” 200-600 kPa (2-6 bar) (optional) steam 130°C Electrical power with steam heating P 13kW (Fusing 25A)
