Franke Finland - DEKO-190
The Deko 190 ward disinfector is designed for use in long-term care facilities, hospitals and health care centres.The Deko 190 ward disinfector is designed for use in long-term care facilities, hospitals and health care centres. It is a microprocessor controlled washing and thermal disinfection machine used for a wide range of articles e.g. bedpans, urine bottles, kidney basins, hand wash basins, bowls and other re-usable items. The Deko 190's cleaning and thermal disinfecting efficiency have been stringently tested and approved internationally. Its unique, patented water circulation washing principle results in outstanding mechanical washing efficiency with the minimum usage of water and energy. The water circulation washing principle allows for a longer and more efficient washing stage resulting in a standard of cleaning that cannot be matched by flusher disinfectors. The Deko 190 is the only disinfector in the world using this revolutionary washing technique. The Deko 190 also comes with a detergent pump included as standard equipment, dosing the correct amount of detergent into the circulating water. This allows the detergent to penetrate all surfaces of the load items, internal pipework, chamber and water tank of the machine. Disinfection is carried out by steam, internally generated in an unpressurized boiler. Deko 190's internal water and steam process completely prevents unpleasant odors and bacterial growth inside the machine. The Deko 190 is also the only machine that accomplishes disinfection of the water tank, piping, outlet and chamber each cycle. The Deko 190's design allows for the automatic emptying of bedpans and urine bottles upon closing of the machine door. This critical feature minimizes staff exposure to infectious bodily substances. The Deko 190 is constructed to withstand continuous use, taking into account the demanding requirements for thorough cleaning and disinfection. It is constructed of stainless steel and all of the components have undergone the most stringent tests and quality controls.
FORUMSView All (5)
0Replies6 years ago | DEKO 190 Error DEKO 190 giving error code 7. can you help, please? Reply |
2Replies7 years ago | Washer dont start (err 9) The device does not respond when you turn on. If you activate a contactor C2 device displays error 9 and switches off. I read about the water level sensor where he is? He had someone a similar problem? Reply |
0Replies8 years ago | Deko 190 The DEKO 190 in our hospital is showing Er6. Does anyone know the meaning of this code? Reply |
• Five variable programs. • Automatic emptying by closing the door. • Automatic detergent dosage system. • Three rotating jets. • Four fixed spray nozzles. • Door safety lock prevents opening during cycle. • Free-standing. • Front-loading.
[*] Heating power 6.6 kW [*] Circulation pump 1.5 kW, output 600 l/min [*] Water consumption 47 l/cycle [*] Energy consumption 0.4 kWh/cycle [*] Inlet minimum/maximum water pressure 1-8 bar, 15-115 psi [*] Heat transmission 1-3 bar, 15-45 psi [*] Net Weight 102kg/225 lbs
