Getinge - 8666
by Getinge
Getinge 8666/8668 Washer-Disinfectors offer the most reliable cleaning and disinfection for Central Sterile Processing/CSSD or OR/point-of-use Sterile Processing/TSSU. Advanced automation capabilities provide a choice of automated loading and unloading to minimize staff intervention and increase productivity. In addition, highly-efficient heat transfer technology optimizes the drying cycle, while the unit's 316L stainless steel wash chamber provides superior corrosion resistance.
1Reply11 days ago | Getinge 86 series washer Getting erro code 11030 low temp chamber. Phase washing 1. What could be causing that error? Reply |
1Replya year ago | Dryer fans Dryer fans not activating, I manually turned them on on service mode, and I have no power going to them, can anyone help. Fyi, Getinge tech support was unable to help me with this problem. Equipment: Getinge - 8666 Reply |
7Replies3 years ago | door adjustment I have an automatic door and have found that it has dropped about a 16th to 8th of an inch. How do I adjust this door to raise it? Reply |
Chamber volume L / Cu ft 314 / 11.1
Chamber width mm / in 660 / 26
Chamber depth 720 / 28
Chamber height 660 / 26
DIN 1/1* trays/load pcs 12
SPRI II** trays/load pcs 18
